Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Plant 3D Issue regarding opening a project
info9JGQN
Observer Observer
info9JGQN
Observer
Observer
Plant 3D project is not opening due to Authentication issue. It is showing errors like Failed to load cache , Login failed & The login is from an untrusted domain and cannot be used with integrated authentication. The project is a SQL server project with Windows Authentication. A machine is set a SQL Server. The project is working fine on that machine only and not on other machines. This happened after we updated the machine on which SQL server is installed. It was working fine till yesterday.
DVaquand
Hello @info9JGQN
If your project is not collaborative, you can always, from the workstation where the project is still running, switch your SQL Server project to SQLite using the PLANTADMINPROJECTBACKUP command. Repair the problem with your SQL server station. From your OK server station you can convert your SQLite project into SQL server using the "PnPProjectMaintenance.exe" application.
This could resolve the situation while your SQL Server license is being repaired.
Note: Always make a security backup.
== French ==
Si vous projet n'est pas collaboratif, vous pouvez toujour, depuis le poste où le projet fonctionne encore, basculer votre projet SQL Server en SQLite par la commande PLANTADMINPROJECTBACKUP. Réparer le problème de votre poste serveur SQL. Dès votre poste serveur OK vous pourrez convertir votre projet SQLite en SQL server par l'application "PnPProjectMaintenance.exe".
Cela pourra débloquer la situation durant le temps de la réparation de votre licence SQL Server.
Note : Toujours faire une sauvegarde de sécurité.
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
lauri_barnhart
Hello, @info9JGQN,
Just checking in—did the responses shared by @DVaquand help clarify your question?
If so, please consider clicking the "Accept Solution" button. Doing so helps others in the community find answers to similar issues.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
All the best,
Lauri | Community Manager
