Announcements
Plant 3D for water pipe connection details in Civil 3D - overkill?
m_kingdon
m_kingdon
Hi folks, I am a Civil 3D user who is wondering if Plant 3D might have a solution to a problem I have encountered.  I want to model some water pipe connection details including reducers / tee-junctions and sluice valves etc.
Civil 3D has these parts in the Pressure Pipe workflow, but the workflow is optimised for running long pipes under a surface, but it seems very bad at accurate detailing i.e getting pipes and fittings to snap together.
Is Plant3D a good alternative?  Or is it massively overkill for what I need?  I am not sure where to begin to be honest.  I am using Metric / New Zealand pipes and fixtures, mostly from these two catalogues.
https://www.hyndswater.co.nz/product/ductile-iron-fittings/
https://www.hyndswater.co.nz/product/hawle-e2-flanged-gate-valve/
What I want to model in 3DWhat I want to model in 3DWhat I make in Civil 3DWhat I make in Civil 3DThe best I can doThe best I can do
Mike Kingdon
Civil 3D Zealot
Tomislav.Golubovic
Do you need to make fabrication drawings and get BOM's of things like the pipe, valves, flanges and gaskets?
m_kingdon
A schedule of quantities would be useful but not needed.  I only really need to draw a few details for some junctions.  A few pipes and parts, click them together and produce an isometric drawing and plan view.
Mike Kingdon
Civil 3D Zealot
Tomislav.Golubovic
Your hardest part would be making the catalogs and specs. It comes with catalogs already, or if you look on the Plant3D App Store, there's more free or paid catalogs you can use. Also you'd be using projects in millimetres, and close to 0,0 so there'd be a bit of fidgeting to XREF P3D and C3D models, but its not a deal breaker. Just follow some rules.
Michiel.Valcke
honestly, if you need it to be mechanically correct, and it is very limited in size, I would even suggest using Inventor. Plant 3D uses very simplified geometry and is first and foremost concerned with the piping and process data. It's strength lies in being able to add metadata to your parts and link that to orthographic drawings, generate iso's and reports. Creating a fully realistic 3D design is more in Inventor's ballpark. But Inventor cannot generate an isometric, if you use the Tube & Pipe module you can generate a PCF file with the isogen function, or you can create a manual isometric view. But that is not the same as an iso from plant 3D.
Michiel.Valcke
There is a workflow to create the part in Inventor and publish it to the Civil3D library so you can have the correct part in Civil 3D.
Check out the Infrastructure Parts Editor for Civil 3D:
https://help.autodesk.com/view/CIV3D/2025/ENU/?guid=GUID-38B22623-DADC-40E1-818D-2FC51AD707E1
And check out this Autodesk University seminar: (there are others)
https://www.autodesk.com/autodesk-university/class/Custom-Content-InfraWorks-Using-Infrastructure-Pa...
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
