Hi All,
Is it possible to automatically add pipe supports into a piping model at a defined interval? Say I have the following model and want to add in pipe supports at all red locations (6m intervals).
Is there some sort of pipe support add command that all details can be passed via the AutoCAD command line (then VBA can be used to automate the process), or can you add pipe supports into the drawing via the Plant 3D SQLite database? enabling automation via SQL programming? or another method I am not aware of?
Thanks in advance for any assistance! 🙂
Cheers,
Josh
