Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Plant 3D 2025 - P&ID - Layer by Service
ljboxer1983
Message 1 of 8
ljboxer1983
Hi All,
Can P&IDs be auto-layered by their "Service" property?
I know that its possible with the 3D Models, so wondered if it can be done with the P&IDs?
Replies (7)
Message 2 of 8
DVaquand
Hello @ljboxer1983
You can use P&ID painting
== French ==
Vous pouvez utiliser P&ID peinture
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
Message 3 of 8
ljboxer1983
Doesnt this just colour them? I need for the layers to be changed
Message 4 of 8
DVaquand
Hello @ljboxer1983
At the layer level, P&ID objects are not managed as in 3D.
Except for a specific application, it is not possible to automatically change the layer of P&ID objects as can be done in 3D.
== French ==
Au niveau des calques les objets P&ID ne pas gérés comme en 3D.
Sauf application particulière, il n'est pas possible de changer automatiquement le calque des objets P&ID comme peut le faire la 3D.
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cordialement
Dominique VAQUAND
www.dovaq.fr
Message 5 of 8
Tomislav.Golubovic
Only other way would be to make new process lines for each service and then change the properties of those lines to be put on the service they are.
Message 6 of 8
Michiel.Valcke
You can change the layers with a simple AutoLisp routine, but you'll need .NET to read acquisition properties or read the service property from the PipeLineGroup. So if you want a tool to do this, I can't imagine it's very complex, you will need to develop it in .NET.
It might be a nice first project.
Message 7 of 8
ljboxer1983
This is interesting, is there any where I could find people with .NET and lisp experience specifically for Plant 3D?
Message 8 of 8
Michiel.Valcke
There are several people on these forums that have the necessary .NET experience for developing such a feature.
Or you can check out the P3D developers' corner
https://aps.autodesk.com/developer/overview/autocad-plant-3d-and-pid?_ga=2.64267628.2146251635.16273...
Follow this tutorial to create your first AutoCAD plugin:
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/6kRFCS0mCalWLwAOpP9pNT.html
combine the information from the two above and you can try and create this plugin yourself.
