Good morning,
Our tool palette displays many many o-lets. Is there a way to reduce this? Maybe have one option for each type? Our branch table is set up and works fine, but it's tedious when we need to add a stand-a-lone o-let. The attached image is less than half of what is in the o-let section.
Thank you for your help!
No way to configure tool palettes. I do recommend using the Spec View palette as it's easier to navigate and you have the option to pick the correct size, rather than having to switch the size after inserting a reducing item.
I like the idea of turning off the tool palettes and using the spec view to select parts, but I always have to turn the palettes back on to insert a pipe support. Am I missing something?
