Pipe Tees (Orientation)
David.Broughton2
David.Broughton2
Is it possible to rotate a pipe tee to select the correct orientation of the fitting please?
In the example below I need the inlet flow to be into the branch and not through the main leg of the component.
Many thanks.
DVaquand
Hello
Press the CONTROL key to set the connection point of the tee
__french ==
Appuyez sur la touche CONTROL pour définir le point de connexion du té
Cordialement
Dominique VAQUAND
www.dovaq.fr
Si mon message propose une solution, veuillez cliquer sur "Accepter comme solution"
If my post offers a solution, please click "Accept as Solution"
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
h_eger
Dear @David.Broughton2 ,
yes press F1
https://help.autodesk.com/view/PLNT3D/2024/ENU/?guid=GUID-A7DA946D-E0F2-4D69-9BC2-AA7C8BFF4313
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
David.Broughton2
H.Eger; 'yes, press F1'.
I guess this would just load the help files...................?
h_eger
Yes, and with the right search query in the help file you can sometimes find a solution.
Otherwise I see great potential for a Plant 3D training.
Hartmut Eger
Senior Engineer
XING | LinkedIn
