Pipe support on pipe support symbol not shown in isometric drawing
Nuttapol_s7MCX4
Nuttapol_s7MCX4
Dear all,
Some node on my pipe have 2type of pipe support(welded stanchion rest on spring support), after I generate isometric drawing, bill of material is shown both but a symbol of spring support is not shown.
Supports on support command has already done.
Please advise me
IsoIso
3D model3D model
h_eger
@Nuttapol_s7MCX4 ,
which SKEY did you choose for your spring support?
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Nuttapol_s7MCX4
@h_eger
SKEY of spring support is "SPRG".
h_eger
@Nuttapol_s7MCX4 ,
Both supports are connected to the pipeline in 3D?
Or have you connected the two with
Hartmut Eger
Senior Engineer
XING | LinkedIn
Nuttapol_s7MCX4
@h_eger
I connect pipe support with command "Supports on Supports".
h_eger
@Nuttapol_s7MCX4 ,
Nice try, but that's not how it works!
You have to connect both supports with the pipeline otherwise the system does not recognize during the isogeneration that there are 2 parts to be displayed.
This procedure should also be explained in every training course.
Hartmut Eger
Senior Engineer
XING | LinkedIn
