Pipe Size in Property Palette
Tbaumgartner2LS3E
Tbaumgartner2LS3E
I am having an issue changing the size of a pipe via the Property Palette in Plant3D.
I am able to use the Palette to change the size of a pipe ONLY when I place it from my P&ID Line list.
However if I run a new pipe (even selecting size and spec) that is not from a P&ID, I am not able to change the size of the pipe.(see screenshot below)
Has anyone run into something like this? I am very confident this is due to a project setting because my exact specs work fine on other projects.
AndyDavisArkance
I'm not aware of any project setting that may affect this.
The list of available sizes should reflect the sizes of pipe available within the same Part Family in the spec.  If you have pipes in more than one part family, (maybe different schedules) you will only see sizes within the same family.
Andy
Andy Davis
Industry Specialist
ARKANCE
