See below for some settings I've tweaked in the past to help performance. Please don't use them as-is. Test (and test some more) and adapt to your needs. They are in LISP form here but you can type the commands in manually to see if they help at all.
;############################### PLANT 3D SPEED OPTIMIZATION TOOLS ###############################
(defun c:KpP3dInsulDispSettings ()
; Note: Disable Windows Aero to increase performance. Also turn off windows transparency.
;------------------- Command Settings -------------------
(command "PLANTINSULATIONDISPLAY" "0"); Hide Plant insulation
(command "PLANTINSULATIONMODE" "simplifiedPartial")
(command "VIEWRES" "Y" 100); sets viewres low - default is 1000
; (command "VSCURRENT" "2dwireframe")
;------------------- 3DCONFIG Settings -------------------
(command "-GRAPHICSCONFIG" "A" "on" "4" "Exit"); Turn on adaptive degradation
(command "-GRAPHICSCONFIG" "D" "off" "Exit"); Turn off dynamic tesselation
(command "-GRAPHICSCONFIG" "G" "D" "on" "Exit"); Turn on "Discard Backfaces"
;(command "-GRAPHICSCONFIG" "L" "H" "E" "on" "Exit"); Turn on Hardware Accelleration
;------------------- Plant 3D System Variables -------------------
;(setvar "PLANTLOCKFADECTL" 0)
;(setvar "PLANTPIPESILHDISPLAY" 0)
;(setvar "PLANTPROPMISMATCHDISPLAY" 0)
;(setvar "PLANTSAVEDETAIL" 0)
;(setvar "PLANTWELDDISPLAY" 0)
;------------------- AutoCAD System Variables -------------------
(if (/= (getvar "cipmode") 0) (prompt "\nRun customerinvolvementprogram to disable."))
(setvar "DISPSILH" 0)
(setvar "DRAWORDERCTL" 0) ;speeds up regeneration when switching tilemodes and when regenerating in model space
(setvar "ISOLINES" 6)
(setvar "VTENABLE" 0) ;disables smooth view transitions when zooming in/out (makes zooming instantaneous)
(setvar "WHIPTHREAD" 3) ;0 - use only a single processor (default), 1 - regen done on multiple CPUs, 2 - redraw done on multiple CPUs, 3 - both regens and redraws done on multiple CPUs
(princ)
(defun c:OPTIMIZEON ()
; (command "PLANTCONNECTIONMARKER" "1"); Set to 0 to turn off drips
; (command "PLANTPLACEHOLDERDISPLAY" "0"); turn off placeholders
; (command "PLANTSTEELSETREP" "SHAPE"); set steel graphics
(command "_-SCALELISTEDIT" "_R" "_Y" "_E"); get rid of extra scale list entries
; (command "-GRAPHICSCONFIG" "L" "H" "E" "on" "Exit"); Turn on Hardware Accelleration
; (setvar "PLANTLOCKFADECTL" 0)
; (setvar "PLANTPROPMISMATCHDISPLAY" 0)
; (setvar "PLANTSAVEDETAIL" 0)
; (setvar "PLANTWELDDISPLAY" 0)
; (setvar "DYNMODE" 0)
; (setvar "DYNTOOLTIPS" 0)
(setvar "FACETRES" 0.05)
(setvar "HPDLGMODE" 1) ;displays hatch/gradient box for items selected in drawing
(setvar "HPMAXLINES" 100000)
(setvar "HPQUICKPREVIEW" 0) ;disables hatch preview
(setvar "INTELLIGENTUPDATE" 1)
(setvar "ISAVEPERCENT" 50)
; (setvar "LAYERDLGMODE" 0) ;speeds up loading of layers palette
(setvar "LOGFILEMODE" 0)
(setvar "LWDISPLAY" 0)
; (setvar "MBUTTONPAN" 1) ;middle button brings up snap menu, (set to 1) – middle button is PAN command
; (setvar "PICKADD" 1) ;enables subsequent selections when modifying properties
; (setvar "PICKFIRST" 1)
; (setvar "PREVIEWEFFECT" 0)
; (setvar "PREVIEWFILTER" 63)
; (setvar "QPMODE" 0) ;disables Quick Properties Palette for items selected in the drawing
; (setvar "ROLLOVERTIPS" 0) ;disables rollover tips
; (setvar "RTDISPLAY" 0)
; (setvar "SAVEFIDELITY" 0)
; (setvar "SAVETIME" 40)
; (setvar "SELECTIONCYCLING" 0) ;turns selection cycling/overlapping off
; (setvar "SELECTIONPREVIEW" 0) ;disables selection previewing
; (setvar "SHOWLAYERUSAGE" 0)
; (setvar "SNAPMODE" 0)
; (setvar "SOLIDCHECK" 0)
; (setvar "SOLIDHIST" 0)
; (setvar "TEXTQLTY" 10)
; (setvar "THUMBSIZE" 0)
; (setvar "TOOLTIPS" 0)
; (setvar "TREEDEPTH" 3020) ;Turns on spatial indexing. An integer of up to five digits is valid. The first three digits refer to model space, and the remaining two digits refer to paper space.
; (setvar "UCSDETECT" 0) ;Controls whether dynamic UCS acquisition is active or not
; (setvar "UOSNAP" 1) ;Determines whether object snapping is active for geometry in DWF, DWFx, PDF, and DGN underlays that are attached to the drawing
; (setvar "VIEWUPDATEAUTO" 0) ;Controls whether model documentation drawing views are updated automatically when the source model changes
; (setvar "VSMATERIALMODE" 0) ;Controls the display of materials in the current viewport
(setvar "VSSHADOWS" 0) ;Controls whether a visual style displays shadows.
(princ)
(defun c:OPTIMIZEOFF ()
; (command "PLANTINSULATIONDISPLAY" "1")
; (command "PLANTINSULATIONMODE" "simplifiedPartial")
; (command "PLANTPLACEHOLDERDISPLAY" "1")
(command "VIEWRES" "Y" 1000)
; (setvar "PLANTPIPESILHDISPLAY" 0)
; (setvar "PLANTWELDDISPLAY" 1)
(setvar "DRAWORDERCTL" 3) ;speeds up regeneration when switching tilemodes and when regenerating in model space
(setvar "FACETRES" 0.5)
; (setvar "HPDLGMODE" 1) ;displays hatch/gradient box for items selected in drawing
; (setvar "HPQUICKPREVIEW" 0) ;disables hatch preview
; (setvar "INTELLIGENTUPDATE" 1)
; (setvar "ISAVEPERCENT" 50)
; (setvar "LAYERDLGMODE" 1) ;speeds up loading of layers palette
; (setvar "LOGFILEMODE" 0)
; (setvar "LWDISPLAY" 0)
; (setvar "PICKADD" 2) ;enables subsequent selections when modifying properties
; (setvar "SELECTIONPREVIEW" 2) ;disables selection previewing
; (setvar "SOLIDCHECK" 1) ;Turns 3D solid validation on and off for the current session.
; (setvar "SOLIDHIST" 1)
; (setvar "TEXTQLTY" 50)
; (setvar "UOSNAP" 0) ;Determines whether object snapping is active for geometry in DWF, DWFx, PDF, and DGN underlays that are attached to the drawing
; (setvar "VIEWUPDATEAUTO" 1) ;Controls whether model documentation drawing views are updated automatically when the source model changes
; (setvar "VSMATERIALMODE" 1) ;Controls the display of materials in the current viewport
; (setvar "VSSHADOWS" 0) ;Controls whether a visual style displays shadows.
(princ)
