Pipe Line Group.Line Number when whithin sheet
Srisurya
Srisurya
Hello Experts,
As we define Pipe Line Group.Line Number for OPC connectors.
We will not use this fied within a sheet,thus results ???
SriSurya Rao Lankapalli
Dan.Scales
Hi @Srisurya,
If the properties are not populated with any data, then the ? symbol is shown in the Pipeline Tag annotation. This is unavoidable.
Once the OPC's are connected the properties from the tagged lines will be inherited by the un-tagged line and the ? will be replaced with the relevant data.
Dan
Dan Scales
Srisurya
Thanking you for reply.
I do not have any problem with OPC lines.
Dan.Scales
Hi @Srisurya,
If you tag includes the Pipe Line Group.Line Number property and you do not  add a line number then the default Pipeline Tag annotation will display a "?" symbol.
If you do not want that, then you can create an new annotation that does not include the Line Number.
The screen shot shows the default annotation on the left and a new annotation on the right:
As you can see, the new annotation does not include the Line Number property.
Dan
Dan Scales
