Pipe Cut Symbol
Pipe Cut Symbol
Anyone know why my pipe cut symbol will just stop working?  I have multiple views on this page where the symbol works as intended.  But my latest view it won't come in.
I can create a view, adjust the cube to cut the pipe and add it to my sheet.  The symbol comes in fine.  When I go back to edit the view and make the cube smaller, the view shows up as below.
Dan.Scales
Hi @Anonymous,
I can't reproduce this issue in a simple test project.
How often does it occur for you? Also, if you re-edit the view are the symbols drawn correctly?
Dan
Dan Scales
Hey @Dan.Scales,
This was just happening on a single view at the time and it doesn't happen often.  I kept trying to edit the view, adjust the scale, adjust the view cube, but none of that worked.  The only way to get it to properly come in was to delete and create a new view.  I also had to go in and add a jog to the view cube as well.
hamilton_pereira2LLWA
Community Visitor
Community Visitor
This is ok, but and in ortho view right, left or front views? I try it, but the line in the cut of pipe point keeps appearing...
