PID VALVE LABEL breaks/covers a part of the line
bbeata0114
bbeata0114
Hi!
Our valve labels contain the size upper the valve and a serial number under the valve. In most cases it works fine.
But sometimes when I assign the valve some part of the pipeline disappaers. In happens usually when there is a channge a direction of the line. I attach a photo. On the left valve you can see my problem, the right one is the good one.
But it isn't too close to the vertical line I think it shouldn't do this.
Has anyone seen something similar? What could be the problem?
Thank you.
AndyDavisArkance
I think you've added the wrong screenshot.  You've attached the block definition not how it appears in your drawing.
Andy
Andy Davis
Industry Specialist
ARKANCE
bbeata0114
Thank you. You're right. I replaced it.
