PDF Layer Problmes (Plant 3D 2018)
This widget could not be displayed.
Hello Everyone,
I know this topic has been covered a lot, but none of the solutions I've found to previous posts has helped.  When I print a PID drawing to PDF, regardless of how I do it (export PDF, microsoft print to PDF, etc...), I only end up with Layer 0, and the two paper space layers I have. The drawing has dozens of layers, so I'm missing several. All layers have the print option enabled, are unfrozen and turned on in the layer properties tab, and it doesn't seem to matter if model space or layer space is active.  I've printed other drawings successfully, so it' s something about this particular drawing that's causing the issue.  Any ideas?
Hi Trevor - did you ever find a solution to this? I have similar issue regards seeing layers on my pdf.
Unfortunately, no. I started having this issue around the time I upgraded to Adobe Pro, so I suspected it had something to do with that. Any chance you had a similar situation?
