P3D Spec error with importing into FARO As-Built
Gavin.DonaldC5SZY
Gavin.DonaldC5SZY
Hello, I'm hoping someone from the community can shine a light on this...
We use P3D and FARO As-Built to automatically detect pipework from our laser scan data. The problem is that when we try to import one of our piping specs (.pspc file) into As-Built, we get a txt file with a bunch of errors, see attached txt file.
I've raised this issue with FARO but they are unable to shine a light on this at the moment. I'm wondering if there is a problem with how our spec has been created and if there's anything I can change to make it work?
Any help appreciated.
RRienWNFHV
I was hoping that you might have found the issue that you faced when importing the catalog.
We are looking at the Faro As-Built software now and will want to perform this same task.
