AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
P3D Settings
3 REPLIES 3
657 Views, 3 Replies
P3D Settings
I have a couple issues regarding settings for Plant 3D and wonder if anyone has solutions...
1) Tool Pallet - How and the heck do you permanantly turn it off so it will not reappear on the screen whenever you restart P3D or change menus?  I know how to manually open the tool pallet if needed but most of the time it is just an annoyance.  (I know you can turn it off using CTRL-3 but I would rather that it doesn't appear unless I want it to).
2) When performing a LOFT operation is there a way to automatically select "RULED" as the default instead of having to manually select that option each and every time?  Ruled is the only option I ever use.
These are 2 things I cannot seem to find any info on or solutions for so I truly appreciate any help to relieve these daily annoyances.
Chuck
Upper Consulting, Inc.
www.upperconsulting.com
P3D Settings
Chuck
3 REPLIES 3
dave.wolfe
dave.wolfe
With Plant 3D, the toolpalettes will always be turned on when AutoCAD starts up despite workspace settings. I think the only way around it would to be some sort of lisp or macro to call the toolpalettesclose command after AutoCAD starts up.
I usually create macros for a button or toolpalette to change default command behavior.
Edwin has a great series on how to create new buttons.
http://cad-notes.com/2012/02/exploring-autocad-cui-introduction-1/
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
jason.drew
jason.drew
HI Chuck,
The default setting for ruled on lofted objects can be set through the system variable LOFTNORMALS:
Thank you,
Jason Drew
Designated Support Specialist
HI Chuck,
Thank you,
Jason Drew
in reply to: jason.drew
Thanks Jason. Problem solved
Chuck
Chuck
