P3D Line Group - Class definition Tree node - Reoder
milic.srdjan
milic.srdjan
Good morning,
Is it possible to reorder Property Name, after we put new one in P3D Line group.
Picture below. I put several new ones , like
Operating Pressure
Operating Temperature
Design Pressure
Design Temperature
etc...
Look at picture below. Is it possible to reorder them,(with SQL editor) to bi different property Name column order.
Thank You in advance,
Srdjan
p.s If I during Property name creation make some spelling error, is it possible with SQL Editor to correct that.
CarstenBeinecke
it is possible. I try to create a video, but it may take me till tomorrow.
Carsten
PlantTools on Facebook
If my post offers a solution, please click "Accept as Solution"
CarstenBeinecke
Here you go.
AKN_Reorder_Properties_171026
Carsten
milic.srdjan
Many kudos for You,
Works as a charm, perfect, and open a lot of other possibilities.
Thank You a lot,
Srdjan
jeroentilroe
Does someone know how to update the order of the properties for a collobaration project? I can modify them in the cache file but when that is refreshed from ACC the order is the old order again.
Is there a way to force the changes to the collobaration project?
CarstenBeinecke
Collaboration aren't possible AFAIK. You may have to create a project backup, fix the order in the backed up project and then share the project again.
Or you can use our PlantExpressTools where you can rearrange the properties in its PropertiesPalette.
Carsten
Zhars
I just tried on a collaboration project and it does work!  I checked out the Project Setup, made the changes to the .dcf and checked the project back in.
