P3D and Vault
couple issues for me.
1) You have 'Project XYZ' being used by 'User A' They have 20 files checked out. Something happens to their computer, doesn't matter what, but the project gets wiped - with the 20 files checked out.
They download 'Project XYZ' again, but the 20 files are checked out by 'User A' and unable to be checked out ever again by anyone, including 'User A'
Is there anyway to fix this?
2) Just happened. I tried to check in a 21 files - ortho template files - into vault. It didn't work - had an error.. now the files all exist in the project, but they are not in the project.. even checked with Vault Workgroups - not there.. so I had to basically rename all the files to copy them in and check them into vault.
Any suggestions? or just a fluke of the software.
()2 i think is just bad luck only happened once.. but (1) is a big issue. It happens, IS there any way to fix it? Using Vault Workgroups to delete the offending file destroys the project...
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
