I would like to know how I set the line tag to my specifications?
For example: 10"-VB-001-CS1-WH1.
I am not able to change the default settings as attached.
I am learning to work with 3d plant.
Thank you.
Solved by rbt. Go to Solution.
From within your project manager:
follow the pull downs from:
project setup-Non engineering-pipe line group-and make your custom set-up
You want to make the changes in the Line segment settings first. Its really reordering the options there. Pipe line Group just contains the number by default.
