Ok, so I did what you said. It works. Now, I have to do this for the next dozen! of items!
If I Edit/Add Symbol for each and every single item it works. The reason why in ISO autonozzle won't work: it was set on ISO Assumed Nozzle. When I changed it to ISO Flanged it works the autonozzle for my Conical Vessel in my example.
But I cannot do this kind of thing for every valve, tank and other equipment!
I mean why ISO Assumed nozzle won't work propery?
Next part, I did manage to add PIP symbol to ISO project; however, I need more symbols from PIP to add; this means that for every symbol that I want I have to manually add them, set-up their properties and so on. Isn't there a workarround? And why all this restrction between ISO and PIP, it's a professional software, not a teacher to restrict me to do something!
Also someone from Autodesk should reply why does it take so long to switch between workspaces for P&ID? At every change the toolpalette becomes floating, it is no longer docked, and it's annoing. It hangs for 3 seconds at every change.
We have here Plant 4D, add-on to Autocad. In it I can add any kind of valve, anykind of equipment instantly!! No lag, no switching workspace no nothing. I have a button with and arrow, keep that pressed and boom, a short list with all the valve types apperas, place (for eg) the ball valve, inherit properties or choose class & other in a small winow. Perfect! Autocad it's toooo graphical, very demanding on a system. Actually, the toolpalette should become a menu item, a tab, this would be great!
Even changing the class is a pain, I loose precious time switching between them.
Sorry if I divagated from the original questions.
So, how about the placing of PIP and ISO symbols? Can I do that as an engineer or I should transform into a programmer?
Thanks alot!
