- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have created several P&ID Off-Page connectors (OPC) calculated properties, to overcome a limitation of the product when building the OPC blocks.
The calculated properties work very well at placement/connected to a line; the issue is when a property used to build the calculated property is changed. The property value does not update automatically.
Is there a way to automate the update of the values? Currently the only way is to disconnect and reconnect the OPCs.
