I have several drawings in AutoCAD P&ID 2017 in a project. When I try to bring a project over it says it migrates properly but then sends in errors about .dxe files not found along with data manager claiming it can't be found. When I let the drawing finish loading the information does come up in data manager and it would be fine but it won't load the customization to the tool pallets as all the PIP pallets have been adjusted to our company standards. Even additional pallets cannot be seen to be loaded. When I try to go into the project set up I get the error "Unhanded exception has occurred in a component of your application... Could not find ...\PIDTo3dClassMapping.xml" and cannot continue past it as all that does is close the error pop-up.
Any help would be appreciated.
