OPC
OPC
leemlemon
OPC
leemlemon
Hi, I want to ask smth about OPC in Plant 3D 2018. it is that I can't Connect lines in the same Drawing although it is claimed that 2018's new feature. Any suggestion?
Artem_Marinin
Hello @leemlemon
OPC works when you connect a line without a number to a line which has a number. The reverse order does not work.
Hope it will help you.
Best Regards,
Artem Marinin
h_eger
Dear @leemlemon,
with an ISO P&ID project 2018.1.1 the internal OPC works perfectly.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
