Only the Pressure Gauge is showing second page.
rafimh2022
rafimh2022
Hi All,
I created following fitting and Pressure gauge in plant 3d and second page of Isometric is showing only the PG and MTO is also not showing for that particular PG. May I know how to show the same pressure gauge in page one?
Thanks & Regards,
Rafi.
quan_hm
Your drawing is still have 1 port open (the water drop) so the gauge may not connect to the fitting pls check that.
If you still not found issue you can upload the drawing here so other can check.
Hoang Minh Quan - Piping design engineer
Autodesk Store for Python Catalog
h_eger
@rafimh2022 ,
How do you think we should solve your problem?
We have no information at all about how you created this valve and with which
Iso Symbol Type:
and
Iso Symbol SKEY
then we would use the PCF file (change file extension to *.txt)
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-include-ins...
and any other information that would allow us to help you!
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
km4504
Use the pressure gauge in the Instrumentation spec or add it to your spec for your piping. This will help with connectivity. It gives you NPT options.
Also make sure that your piping details are set to the smallest size so it shows on the BOM.
If my reply was helpful, please give a Kudos or click the Accept as Solution button below (or both).
