Off page connectors from /to and connector number in AutoCAD Plant 3D 2016
P.foucher
P.foucher
Hello evrybody
i'm trying to setup the opc using this methode:
https://blog.hagerman.com/2013/04/29/autocad-pid-off-page-connector-automation/
i'm running autocad plant 3d 2016
but it doesn't work
what i need is information from and to and the connector number in automatic
does anybady have an issue with that? as you can see on the picture evrything is connected but the information are not linked...?
thank's
@P.foucher
Topic Title has been changed for better findability by @joaquim.moral Original Post: Off page connectors from /to and connector number
George.Endrulat
What does it look like in the block editor through project setup?  Usually if you want to acquire from another drawing you need to make sure that the acquired data in the attribute in the block has an equals sign #(=drawing.number) or something like that based on your setup.
George
If my post offers a solution, please click "Accept as Solution"
Nik4_99
Hi George,
thank you for your reply.
My standard, predefined OPC had attribute
#(TargetObject.ConnectorNumber)
which didn't acquire the number from the connected line connector.
As per your suggestion, I have changed it to
#(=TargetObject.ConnectorNumber)
and now it acquires the number.
Thanks again,
cheers
