AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Nozzle Tag Format
5 REPLIES 5
StaniforthR
1006 Views, 5 Replies
Nozzle Tag Format
Hi Everyone,
Am trying to create a alphabetical tag format for nozzles for a clinets project ( client wants nozzles labeled as A, B, C etc). I have created a tag property called "Nozzle_Tag"("string" property type, "none" for acquisition & only "Visible in object view" box checked). Have also created a Tag format "Nozzle Tag (Letter)",(Field is "TargetObject.Nozzle_Tag[]" and the expression is set to"No Expression". I have set the "TagFormatName" to "Nozzle Tag (Letter)". The problem I am having is that the tag property won't populate in the PLANTNOZZLEADD dialogue box and I only get a "?" in the "Nozzle" selection drop down.
What step have I missed, probably something really simple (must admit am rusty with this as I haven't had to do this in a while).
Any help would be appreciated.
5 REPLIES 5
h_eger
in reply to: StaniforthR
Hi @StaniforthR,
can you provide us with a picture-dokumetation?
Before I give a wrong answer.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
StaniforthR
in reply to: h_eger
Refer to attachments & description in first post,
Captures 1, 2 & 3 show how I have set up the tag format. Capture 4 is the result after I gave it the letter A as the tag designstion.
(Capture 4 is next post only let me add 3 attacments this post)
StaniforthR
Capture 4 attached
h_eger
Hi @StaniforthR,
so can not work with the tag and nozzle!
Plant 3D specifies which data should be used!
When marking it is the value "TAG" everything works only with "TAG"
Your newly created value is ignored by the system!
Create a new "TAG format"
I use the "Type" value for the Nozzles label.
And so my result looks with alphabetical marking of the nozzles
Hartmut Eger
Senior Engineer
XING | LinkedIn
StaniforthR
in reply to: h_eger
Hi @h_eger
Does not work. Have you tried to add a second nozzle with your format? Thanks for your help but have opened an enterprise help desk case and will deal directly with them.
”Boost
