Move/Copy Plant 3D Project SQL Server Lite
tstorzuk
tstorzuk
Trying to find out how to properly move a Plant 3D SQL Server Lite project to a different folder/server location.
I DO NOT want to convert it to a SQL Server project in order to be able to do this.
It is not a project within Vault, nor do I want it to be.
Could someone direct me to the correct procedure please?
h_eger
dear @tstorzuk ,
If you mean a SQLite project, you can simply move your project to another location.
Then start Plant 3D and run Open Project and select the project.xml from the new location.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
matt.worland
Maybe someone else has run into issues or better advice to share, but I haven't found any issues in just copying/moving the folder to a new location. All of the data should be stored in the project folder. The SQLite databases are the dcf files found in the project folder.
If my reply was helpful, please give a "Thumbs Up" or "Accept as Solution"
tstorzuk
@h_eger @matt.worland
Once I move the folder location, then do I have to go into the project set-up and change all of the paths?Plant3DProjectSetupPaths.png
Are there any other steps that need to be done other than changing paths? Something that I'm not thinking of?
h_eger
No
Hartmut Eger
Senior Engineer
XING | LinkedIn
tstorzuk
@h_eger
So I move it from the C:\ to a different drive, and all the paths will update accordingly on their own?
That's impressive!!!
Thanks!!
