- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Whenever i create an isometric drawing from my 3D model, welds appear in the table but the numbering on the drawing is missing. I am using Plant3D 2024.
I have already searched for a solution on the forums (like this one: https://forums.autodesk.com/t5/autocad-plant-3d-forum/plant-3d-2016-isometric-weld-list-shown-but-we...) and I created a few isostyles and modified the .xml file to display all welds (field and shop) but nothing works.
I noticed that in the sample project, isometric drawings have the numbering displayed but when i import my piping into the sample project and extract the isos, the weld numbering is missing.
I am using a custom spec/catalogue built from scratch with socketweld FTG/C connections (it seemed similar to brazed copper connections) and a custom nominal diameter map file.
Does anyone know what causes this issue?
I attached some .pcf files, the spec, the isostyles and the nominal diameter map.
Thanks!
