AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Missing Spool Tag
4 REPLIES 4
kuro143243
208 Views, 4 Replies
Missing Spool Tag
Can someone explain it to me why are there excess spool numbers? it should be 1 and 2 only
4 REPLIES 4
Chitose_Sakuma
in reply to: kuro143243
It looks like your isometric drawing is heavily customized. Would it produce the same results with the standard isometric drawing style? If you could upload the PCF file, we might be able to give you some clues on how to solve the problem.
Shuji Sakuma - Japan
https://www.youtube.com/@AUTOCAD-PLANT-3D-FOR-JAPANESE
kuro143243
in reply to: Chitose_Sakuma
it has the same results with the standard isometric drawing style
Would 2 and 4 be the upper bit of pipe and the branch going east on the screen?
Chitose_Sakuma
Are the lengths of each spool listed anywhere on the isometric drawings?
If so, I would like to know what they are.
