AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Missing equipment templates
1 REPLY 1
Neda.P
1952 Views, 1 Reply
Hi ,
I am ne wto Autocad Plant 3D. I want to use built in equipment template for compressors and tanks and dryers. But there is no template in Plnat 3D. Is there a file of different equipment templates I can download and use in Plant 3D?
1 REPLY 1
matparodi
in reply to: Neda.P
Custom Equipment in Plant 3D
https://knowledge.autodesk.com/support/autocad-plant-3d/getting-started/caas/screencast/Main/Details...
Hi, I don't know if you can see the video I made... you can see the procedure of create a custom equipment.
Just design a custom parametric drawing in 3D, convert in block and save it. Then use the command PLANTEQUIPMENTCONVERT and in the explorer window search for DWG File you save the 3D Block, select it and choose the category for your custom equipment, in this case compressors and tanks and dryers.
If you have any consult just let me Know
Regards
MJ Parodi - BIM Coordinator
”Boost
