Metric PVCu Nominal size chart
JohnHolder
JohnHolder
Anyone have access to a proper metric PVCu Nominal size chart?
Not standard to metric - not sch 40, but metric PVCu?
I'm having issues finding the proper information - or is this going to be country specific?
Eg. China, England, Australia etc.
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
AndyDavisArkance
I'm not sure what you need, but this might be of some use:
 Plastic Pipe Dimensions Chart
Andy
Andy Davis
Industry Specialist
ARKANCE
JohnHolder
Not exactly,
In Australia at least 300mm ND pipe is 315mm OD  -but they call it 300mm.  Similar to Canada and the US calling 6.625" OD pipe 6" ND.
I'm just having major issues finding the proper ND with specs on PVCu piping - and is it similar in China and Europe as Australia?
Graphic from Australia.
It gets confusing in the 200 to 280 range, using the OD values of the pipe vs the ND size.
Master Yoda.
skintsubby
Hi @JohnHolder
Not sure if it's what you are after but have you tried GF ?
<<HERE>>
Regards
Mark
JohnHolder
Yeah I have some of the GF catalogs - just like spears the P3D catalogs are missing so many sizes and fittings we use.  Had to try to find other sources.
Looks like I will have to have the client in each specific country get data sheets so I can modify the spec to conform with local standards.
Master Yoda.
