AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Max Length Pipe Routing Question
1 REPLY 1
ritvizheart089
148 Views, 1 Reply
Getting a bit frustrated...
Modeling a 24" line in Plant3D. In the Spec Editor I set pipe length to 20' lengths. As I begin routing pipe from start point I notice that the first pipe break is in line with a stub in. What I would like to do is first run a 10' length of pipe and then continue 20' lengths from there. When I try to do that P3D automatically keeps changing the first piece of pipe off the flange from 10' to 20'. https://xender.vip/ https://nox.tips/
Any ideas out there??? Thanks!
1 REPLY 1
h_eger
in reply to: ritvizheart089
Dear @ritvizheart089 ,
construct your pipeline length to 30' and place a weld after 10'. This gives you 2 pipeline segments with one 10' and one 20'.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
