AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Material Code not showing for fasteners on iso BOM
5 REPLIES 5
SoftFit_Iain
503 Views, 5 Replies
Hi Folks,
I'm having trouble showing material codes on our Iso BOM for fasteners, it works for all other items where I have input material codes in the spec. It also shows in data manager, so i'm assuming there is a configuration somewhere for what fasteners will show on a BOM.
Please see attached snips for reference.
Any help would be appreciated.
Iain
Labels (2)
5 REPLIES 5
h_eger
in reply to: SoftFit_Iain
dEAR @SoftFit_Iain ;
Are you sure it is MATERIAL CODE and not MATERIAL?
For me it is MATERIAL which is displayed in the iso parts list.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Out of the box, the Material property is included in the BOM.
You can add the Material Code property through project setup.
Hope this helps.
Andy
Andy Davis
Industry Specialist
Cadline Ltd.
SoftFit_Iain
in reply to: h_eger
Yes I agree it should be material... unfortunately whilst creating the specs in excel I have filled in the material code column with all materials and (maybe mistakenly) thought it will not be an issue as I can select material code in the iso set up and change the text as a workaround.
Now I'm having issues, I think I will edit the specs to suit.
Hi Andy, yeah the strange thing is I have selected material code to show on the iso's BOM table. See attached snip.
I'm of the thought there must be a configuration somewhere for fasteners, but cant work it out.
SoftFit_Iain
There was something like a line break in the text prior to the material text I had input... copy, paste error.
Thanks for your input regardless of my schoolboy error!!
