Mapping Inline Instrument with Plug - Validation error
Hi All,
I have problems in mapping inline instuments as Plug in 3D. We have buy a 3D spec where the instruments are created as Plug. Mine goal is to mapping inline instruments with plug to make them selectable in P&ID Line list.
Follows the settings for an example Flow indicator:
P&ID Class definition:
P&ID Object Mapping:
Plug setting:
In this way the instrument is selectable from the P&ID Line list, but when i make the validate, plant says that the element doesn't exist in 3D.
Anyone can says me what's wrong?
Thanks.
h_eger
Hi @Anonymous,
your inline instruments do not work as a plug!
Inline instruments should be configured as an inline instrument in the PuID afterwards the mapping in Plant 3D also works (starting from P3D 2018)
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Thanks @h_eger,
What do you mean with "Inline instruments should be configured as an inline instrument in the PuID"?
h_eger
Hi @Anonymous,
this configuration is not supported by Plant PuID and Plant 3D!
Hartmut Eger
Senior Engineer
XING | LinkedIn
h_eger
Hi @Anonymous,
for Example:
Hartmut Eger
Senior Engineer
XING | LinkedIn
