<ValveCode> Property
I am getting the attached error when selecting the Valve report in the data manager. How can I fix this? Thanks.
h_eger
Dear @Anonymous,
in the "Project Configuration" under "Reports" - "Valve List" "Modify ..." you can make the necessary changes so that the Repert re-works.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Thank you. Your solution did fix the error. I chose to add the property back in instead.
