AutoCAD Plant 3D Forum
Line Number Tag in Isometric Drawing
2 REPLIES 2
michael.solomons
224 Views, 2 Replies
Hi all,
This is driving me crazy.....
We are running a P3D (2024) collaboration project in Autodesk Construction Cloud
I have been trying to change the order of the line tag in my Isometrics from the default  (Service-Number-Size-Spec) to (Size-Spec-Service-Number), I have modified the Isoconfig.xml file in the data cache with the project checked out but each time it keeps changing back to its default settings.
Line Number above is incorrect
Default setting above, changed setting below
I have also tried editing the Isoconfig.xml and uploading to the cloud folder but it still keeps changing the settings back, I have tried changing the order in the project setup below but they keep defaulting back to the default setup.
It doesn't seem to matter what I do I cant seem to get the settings to stick, I'm not sure if it's a bug in P3D 2024 as it worked fine on an earlier version, any ideas gratefully received.
2 REPLIES 2
I've been getting the same, but my workaround is to edit the isoconfig.xml, make a copy of it, and if/when it gets overwritten by the one on ACC, I just replace the file locally in my cache folder for the project.
OR
* Do a project backup
* Make the changes to the Isometric Setup on that backed up project (which is sitting on your local drive somewhere)
* Delete the P3D project from ACC
* Re-Collaborate your local project to ACC with the updated Isometric config settings
I had to add a command to checkout the cloud project setup to edit the isoconfig.xml manually outside of project setup. It’s in the Grairec power pack.
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
