Line Number Tag can't assign
Good Morning,
When I try to create a line does not assign the tag of the line and it is not created either. but in the data manager if it appears. This only happens to me with some pipe lines. Someone knows how to fix it?
thank you
jabowabo
I already tried what you tell me.
The solution was a different one. It was necessary to delete the record in the database in order to create it again.
Thank you
Atte.
Marcos
FLAVIOLCRSB
Hola @mmiguelSQ6GE buen día, tengo el mismo problema.
Me podrías indicar cómo se lleva a cabo esta solución ?
"The solution was a different one. It was necessary to delete the record in the database in order to create it again."
Muchas Gracias
Travis_NguyenJ5M5D
Hi mate,
Where can I delete the record in the database?
In data manager or anywhere else?
Thank you,
