Issue with plotting in P&ID when using line weight weights
balasubramaniyanG8A8H
I am facing some issue with the plotting the P&ID drawing.
When  plotting the p&id with line weights ( tried 0.7, 1mm) the arrow appears to be cut some how and its under my equipment  ( green colored one ).
Please help me solve these two difficulties.
1. Even when plot with line weight i want my arrow to be sharp and appear on top of the line whose flow direction its indicating. and stop at the equipment's point properly without invading its space.
2. Is the a easy way to select the draw order for the lines? irrespective of which is drawn first and second. I want my process line ( primary one to be always on top. secondary line to appear below it) and the instruments lines to take the least drawn order priority ( bottom most of the print).
AndyDavisArkance
I can't help with the draw order, but the issue with the rounded flow arrow is because it is drawn as a hatched polyline.  If you delete the polyline from the block definition it will display as a pointed triangle regardless of lineweight settings.
Andy
Andy Davis
Industry Specialist
ARKANCE
