isometrics symbol for flange and dimensions not correct
ahs0nj
ahs0nj
hi i made a cad block based PN10 flange when i connect this flange in 3d its fine. but when i generate isometrics the symbol and dimensions are disturbed. is there any solution for this??? see attached.
AndyDavisArkance
I would take a close look at the block that you have created and check that the ports are positioned and aligned correctly in PlantPartConvert.  The iso looks a little bit misaligned through the flange.
Andy
Andy Davis
Industry Specialist
ARKANCE
ahs0nj
THANK YOU for reply
