Isometrics piping ends at dovetail connection
doruk.yelkenciUFCQF
doruk.yelkenciUFCQF
Hi all,
I have a question about isometrics. Sometimes spools are divided into seperate sheets, which cause confusion at workshop. I am sharing the 3d picture of the spool below. It has two dovetail connection and flanges connects to existing flanges on point cloud.
When I try to get isometrics, one of the dovetail connection is given with seperate sheet. I am using plant 3d Final A2 iso options. I am sharing the isometrics below.
Is there any solituon workaround to get them in one page ?
h_eger
Dear @doruk.yelkenciUFCQF ,
I have tested it with me as far as the replica was possible.
With me everything comes on an iso.
you can try to set the isogeneration to Advanced... and uncheck "Create split points automatically".
may help but there is no guarantee for success.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
doruk.yelkenciUFCQF
I tried your solution but it didnt work.
I deleted the pipe of the branch that is shown in seperate sheet and from unconnected flange I reconnected to main pipe. Now it gives me all in one sheet in isometrics.
h_eger
Thank you for your support!
Hartmut Eger
Senior Engineer
XING | LinkedIn
