We are currently migrating data within this board to improve the community. During this process, posting, replying, editing and other features are temporarily disabled. We sincerely apologize for any inconvenience caused and appreciate your understanding. Thank you for your patience and support.
isometric with inlinebranch not on center line
xavier_ducloyerV4JH8
Hello
I've a pipe with inlinebranch connected with the top of pipe at the same height (not center line).
Is it possible to have this information on the isometric ?
I work with Plant3D 2024
Tomislav.Golubovic
Look at the command line when you run the branch. There's options for offsets, either TOP or BOP or a distance
h_eger
@xavier_ducloyerV4JH8 ,
apart from the coordinates, I have not found any way to get the offset of the connection on the iso.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Sorry but i'm allready able to make the offset in the 3D model, my issue is that the offset doesn't appear on the isosmetric.
Thank you for your answer.
It's quite strange that Autodesk make possible to apply offset in 3D but don't make the necessary to make this offset visible ont the isometric.
I think I'll wait for a few day before closing the topic, perhap's someone else will have a solution.
h_eger
Make a support request to Autodesk.
Hartmut Eger
Senior Engineer
XING | LinkedIn
