Isometric real coordinates problem
Good morning
I have a little problem with isometrics.
I´ve routed a pipe of almost 6km length, now i´m goin to create ISOs of one part of that.
The whole routed pipe is far away from 0.0.0 axys (X:4700 KM/ Y:500KM). This is a big distance that could cause problems, o a brought it back to the 0.0.0 point and rotated it trying to align it as similar to the axys of program as possible.
I routed all pipe and created ISOs correctly. Despite all the routed pipe are not straigth lines like in a process plant (example: a desalination plant) the ISOs look pretty well (all this has been near from 0.0.0 point).
Now i have to move all the pipes to the the real coordinates and rotate them to real angle. I did it and tried to create ISOs, but it didn´t work out well, program send error messages (It also have problem because of the angles and real orientation of pipes, programm can´t do a correct interpretation of drawings in really closed angles). So, for solving this problem i brought back to 0.0.0 point all routed pipe (but keeping the real angle rotation) and at the moment of generating ISOs, in Advanced Iso Creation Options, in Offset Location i wrote down the real coordinates, i clicked OK to create ISOs but failed, programm send error messages, so i had an idea, i kept routed pipe model in 0.0.0 coordinates and also copied the same pipe to the real coordinates, so the model is twice in th screen, in real coordinates and 0.0.0 coordinates, then i went to create ISOs, in advenced options wrote down the real coordinates and.... this time it worked, the programm created ISOs showing the real coordinates in every pipe connection.
Now my problem is, according to the real angle rotation of the model routed pipes (several weird angles), the ISO drawings look weird, not natural, forced angle, not like an average isometric with 45º angle orientation, so as the ISOs are generated according the real routed angle pipes, they are hard to see and read.
My question is, ¿Is there a way to keep my model in 0.0.0 coordinates with the angle rotation aligned to the XYZ axis, generate ISOs with the real coordinates and the real angle and make the ISOs look more normal and natural like an average isometric?, ¿Is there also a way to make appear the north arrow of drawings appear according to the north project and also make appear at the same time another north arrow oriented to the north project (My custom alignement and rotation to the XYZ axis) ?.
