Isometric LDT setup
Isometric LDT setup
Message 1 of 8
Isometric LDT setup
Hi all,
Just looking for a bit of advice. We have setup LDT information for our isometric production, via the network. All is working for everyone on the project, except one person. When this person produces an Isometric he does not get any of the LDT information, which then prompts someone else to create the isometric for him.
Any ideas why only one person in our department would not get the LDT information to produce?
Replies (7)
Message 2 of 8
Dan.Scales
Hi @Anonymous,
Is the path to the LDT file the same on the problem machine as working machines?
I am wondering if they have a different drive letter mapped.
Dan
Dan Scales
Message 3 of 8
Thanks for the reply Dan,
The users machine that isn't working paths to the same file and drives are the mapped correctly as per the rest of the team.
Any other suggestions?
Message 4 of 8
Dan.Scales
Hi @Anonymous,
Could they be using a different version of Plant (missing an update)?
AutoCAD Plant 3D: LDT attribute link for isometric drawing, doesn't work for specific user
Dan
Dan Scales
Message 5 of 8
thanks Dan, think that's the one, see attached images. The user which isn't getting LDT information is running SP1 addon, whereas the rest of are not.
would you agree with that?
Message 6 of 8
Dan.Scales
Hi Richard,
Yes, that certainly would appear to be the cause.
I would recommend getting all users onto the latest update for 2017:
Dan
Dan Scales
Message 7 of 8
jhamilton
Is it possible that the person does not have the same folder rights as the other people?
There was in issue with 2017 where the LDT did not work properly.  We went to 2018 when that was fixed.
Message 8 of 8
I don't think that's a possibility as the LDT is located within the project file structure, which the affected user can access and read/write to the model and drawing file locations.....
I think the issue will be as above... the different versions of P3D run between users here, waiting on IT rolling out the updated version so all users are consistent.
I will update with resolution should that be the case.
