Isometric BOM Pipe Quantity in MM
Srisurya
Message 1 of 10
Srisurya
Dear Experts,
SriSurya Rao Lankapalli
Replies (9)
Message 2 of 10
h_eger
The following changes are necessary for this in the Iso Config.xml of your ISO style:
Standard is: (1)
Modifications are:
<Style Name="MetricPipeLengthAlt" UnitFormat="Decimal" Precision="Precision1" Prefix="" Suffix="mm" Scale="1" Decimal="." />
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 3 of 10
Srisurya
Thanking you for your quick reply.
Its only changing its units but I cant able to change the actual length of pipe ??
I mean the length should be in MM at BOM
Message 4 of 10
h_eger
These changes result in the following change on isometry (red box in BOM)
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 5 of 10
Srisurya
Message 6 of 10
h_eger
In the same line, change "Precision 2" to "Precision 1" and scale "0.001" to "1"
Should work now
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 7 of 10
Srisurya
This made my system hangs for a while.
CPU usage is 25% by PNPiso??
Message 8 of 10
h_eger
Has your problem solved?
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 9 of 10
Srisurya
No,The computer gets  hanged and I kept an Isometric for over night
The result in the morning is like this without dwg files
When I use other style its working good
When I try to copy working style keep my template its not working
Message 10 of 10
h_eger
Can you reset the last changes?
Then again test the Iso generation.
Remote diagnosis is a bit difficult.
Hartmut Eger
Senior Engineer
XING | LinkedIn
