ISO Weld
ISO Weld
hussan.halabi
ISO Weld
hussan.halabi
hi,
is there a possiblity in plant3d to add text to welds number or any combines format with texts and numbers??
thanks for your answer
jabowabo
Yes.
skintsubby
Hi @hussan.halabi
Welcome to these forums.
Not automatic but you can add text in a round about way.
You can change the project setup to "use property from model"
Then in the model click on your weld and manually change the description adding a number and text as you see fit.weld 2.JPG
It means you have to manually number / identify each weld though.
Mark
Not automatic but you can add text in a round about way. Then in the model click on your weld and manually change the description adding a number and text as you see fit.
iso certification singapore
JosephAugustino
Hi.  I've tried this technique to enter an Alpha-Numeric Weld number (i.e. WP-001-6") but the Weld Number property on the Connector will only allow me to enter a number.  Am I doing something wrong?
Joe
DVaquand
Hello
Sorry for my English, which I don't speak and whose post has been translated by Google Translate.
You can easily add prefixes or suffixes to your weld numbers on the isometric.
You will find in link a support (French) describing the procedure.
https://dovaq.fr/download/856/
Regarding the "Weld number" property on the 3D weld, it is an Autodesk bug because if we look at the property is of type "String" but in the database the property is of type "Integer".
Cordialy
https://dovaq.fr/tuyau/
= French =
Bonjour
Vous pouvez tout fait ajouter des préfixes ou suffixes à vos numéros de soudure sur l'isométrique.
Vous trouvez en lien un support (français) décrivant la procédure.
En ce qui concerne la propriété "Numéro de soudure" sur la soudure 3D, c'est un bug Autodesk car si on regarde bien la propriété est du type "Chaine" mais dans la base de données la propriété est du type "Entier".
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
