Iso Symbol Scale
Iso Symbol Scale
Is there a way to scale just a single isometric symbol? There have been requests in the office to make the flow arrow symbol larger on the isometric drawings and as it stands right now, it looks as if it's all symbols per theme or nothing.
You can scale the symbol in the Isometric symbol editor. You can scale the block up using the block editor. See attached images
I tried this earlier this morning and it doesn't work. It's not the same block symbol as the one in the Isometric drawing. See attached
If you scale the Block FlowArrow in your 3D model it will use it for the template to create the isometric flow arrows. Don't worry about this isometric arrows. It may require cutting the iso again, but it will be bigger.  I changed the block named FlowArrow in the IsoSymbol drawing by scaling it up 2x to make it bigger. When you cut Iso's it uses the standard block FlowArrow to make the isometric ones. See attached.
It actually worked the second time. I was on the right track this morning, I just couldn't get the symbol to scale up after regenerating the Iso. Thanks for the help, I've marked your reply as a solution.
