Iso Split
Iso Split
kamel.rhilitz
Message 1 of 14
Iso Split
kamel.rhilitz
Hi Guys
i m encoutring the same issue of isos plitting randomly when i create the isometrics.
the below exemple is one simple line number with 2 valves ,strainer and a filter,  i ve got 2 isos, even though i de activated the automatic split.
how to control this pls?
Replies (13)
Message 2 of 14
h_eger
Dear @kamel.rhilitz ,
can you please upload the PCF file to this ISO so that we can test it.
thanks
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 3 of 14
kamel.rhilitz
thanks for your reply,
ops PCF files are not supported here or what, i cant upload it
Message 4 of 14
kamel.rhilitz
here is it, thank you
Message 5 of 14
h_eger
There is not too much in this PCF file
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 6 of 14
kamel.rhilitz
the filter doesnt show up. strange.
i took an exemple of the permanent issue i have when generating isos. i think plant ignore the connection to an equipment that i create
Message 7 of 14
h_eger
you can upload a drawing with the entire pipe line including equipment
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 8 of 14
kamel.rhilitz
ok
Message 9 of 14
h_eger
Point 1: the flange is on the line number "instrument"
Point 2: this weld seam is also on the line number "instrument"
The filter is a piece of equipment and as soon as all parts are on the pipeline 200, the ISO works.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 10 of 14
kamel.rhilitz
i restarted , created a new project, set all the project set up, and isometric setting, but still it gives two isos for a simple line.
Message 11 of 14
kamel.rhilitz
i resterted from scratch to test if my setting were correct.
i created and equipmnt then 2 4 inch flanged nozzles then with the regular plant run 2 pieces of pipes each side then blind flanges. when i use the command connect it gives me an error...cant understand what s the issue.
Message 12 of 14
h_eger
As long as you design your filter as equipment and not as an in-line object, you will always get 2 isometrics.
You will not get an isometry if all parts are pipe fittings.
Was this topic not addressed in the training?
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 13 of 14
h_eger
Attached is your drawing with the filter as an in-line object, then the ISO looks like this (see appendix 100.dwg)
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 14 of 14
kamel.rhilitz
thank you very much.
actually i dont remember seeing this on the training, do you have any link about the correct way to do create the equipment as inline component?
would you also explain this please " You will not get an isometry if all parts are pipe fittings" would you please send useful links in this regards.
