& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
Hi, Plant 3D Support
I have an issue when generating ISO drawing of Stub-in Pipe
If direction of a pipe (Image A), which stub-in pipe is connected to, is not orthogonal, ISO drawing looks like image B
Image A.
Image B
However, it looks like stub-in pipe is horizontally rotated by 30 Degree from the connected pipe. Is it possible to put angular dimension from connected pipe to stub-in pipe only? (In this case, vertical angle only, like green curcle in Image B)
The Iso looks technically correct and accurate as far as I can tell. I would rank accuracy over aesthetics when it comes to Iso and spool drawings.
But if you're trying to adjust the appearance, some things you could try include:
Isometric generation usually continues to advance and improve with each Plant 3D release. So if you're using an older release, then the 2016 -- or soon ... the 2017 version -- may produce different results as well.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hi, Martin.
Thank you for suggestions.
I can use Offset Rotation temporary, but I need to try different Iso style to achieve better result
Paul
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
