Iso Message Default Enclosure Selection?
EricNyh
Message 1 of 8
EricNyh
Right now on a iso message, the default enclosure selection is 'Box (Round end)'.  Is there a way to change this?  I would like 'Box' to be the default.
I'm using ver 2016.
Thanks!
Replies (7)
Message 2 of 8
h_eger
Click on the drop-down list (1)
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 3 of 8
h_eger
sorry not read correctly.
Unfortunately, there is no way is HC
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 4 of 8
ryan.bales
Autodesk Support
Autodesk Support
Hi Eric,
As @h_eger pointed out, there is no way to set the Iso Message to a specific default.
Ryan Bales
Fusion 360 Product Support
Message 5 of 8
Is there a way to Add a Custom to the Drop Down List?
Message 6 of 8
jabowabo
You cannot modify the list but you can change how each message appears by remapping the annotation schemes/styles for each in the isoconfig.xml file.
Message 7 of 8
hdadgar
Community Visitor
Community Visitor
Is there any way to generate report of Iso message?
Message 8 of 8
jabowabo
Plant 3D does not provide any built-in functionality to access the messages - Report Creator, Data Manager, etc. don't see them. The message data is stored within an Xrecord of the symbol Extension Dictionary. AFAIK, this can only be accessed through the API.
