What are the basic things I should check when an ISO generates a layout but has symbols on top of each other?
What sheet size are you using? Have you tried to setup a larger (24"x32") sheet? If you have a complex pipe run you might have to use a larger sheet size.
Quentin Contreras
Technical Support Specialist
Were you able to resolve the issue?
Quentin Contreras
