I have a custom scripted straight component which is flanged at both ends. When I run an Iso, the component is dimensioned to the back of the flanges instead of the face of the flanges. For Iso purposes I have set up the component as symbol type "PIPE-FIXED" and the Skey as "PIFL". The acad symbol block assigned is "FLANGEDFIXEDPIPE". See attachments for details. I am using Plant 3D 2016 Extension 1. How can I ensure that the Iso dimensions to the face of the flanges?
Can you post a screen shot of the iso block in the block editor?
I cannot get it to work either. I think it has to do with the lack of locating points for pipe/pipe-fixed.
Hi, did you already fix this problem?
I am facing the same problem, which iso symbol type did you define for this?
regards, Jan
